Ok, so I'm about to head to my local store to cancel my order on the 8700k (for now). I'm gonna let it settle for a bit and have Intel have more stock and have the prices go down (maybe). The prices for the motherboards are bloody ridiculous along with the processor itself. rushed launch for sure.
Aaaaaaanyways, back to the topic. I'm gonna be going for a Ryzen build for now but will go for the 8700k later down the road. Here's what I configured:
CPU: AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor  (£184.95 @ Aria PC)
CPU Cooler: Noctua - NH-D15S 82.5 CFM CPU Cooler  (£68.73 @ Eclipse Computers)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  (£135.72 @ Amazon UK)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  (£148.79 @ Aria PC)
Total: £538.19
Generated by PCPartPicker 2017-10-06 11:47 BST+0100
I will be OCing to 4Ghz, but I'm not sure whether to go for a 1600 or 1600x... the price between them isn't that huge. Should I go for a B350 board instead since I won't be using SLI anyway? (I'm planning on having just a 1080Ti)
Should I get the Ripjaws V or keep the Corsair Vengeance LPX?
Thanks in advance,
Sean.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/843149-ryzen-build/
I'd just wait till 8700k prices drop to acceptable levels. Unless your current PC is dead, not worth buying Ryzen when you want Coffee.
Desktop benching:
https://linustechtips.com/topic/843149-ryzen-build/#findComment-10522359
you will need to check the QVL for the RAM you will be using
most reported you can go only up to 2933MHz
any higher and the system will not boot
as for the CPU
i think if possible you could step up to the 1700 will be sweet when pairing with the 1080Ti
the stock AMD cooler with the 1700 is good enough for mild OC
so you save quite a lot by not picking up the aftermarket cooler
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/843149-ryzen-build/#findComment-10522360
its not dead... its just.... old....
as for the CPU
which ram do you recommend for ryzen 1600/1600x?
and what about motherboard? x370 or b350?
36 minutes ago, Strike105X said:
In addition to what dragoon said it should also be noted that even the D15S has a pretty big height, make sure it fits in your desired case.
my define s will handle the nh-d15s just fine :)
Old Rig
https://linustechtips.com/topic/843149-ryzen-build/#findComment-10522447
go with ryzen 1600 as it comes with nice stock cooler with less price tag & you will manually overclock so there wont be any difference between 1600 & 1600x. for board, asus strix b 350 f gaming is an amazing one between all the b350s & should be fine with 1600. but do note, if budget aint factor you can get x370 prime plus or x370 strix too which could be a great investment for future. for ram, it seems samsung b die chips tend to overclock better for ryzen & you might find this link useful.
https://linustechtips.com/topic/843149-ryzen-build/#findComment-10522455
B350 is fine for mild OC. but if you want full blown OC features the X370 is the way to go. Ryzen 7 is best paired with x370. GSkill Flare X are the Ryzen supported RAM.
Go for the R7 1700.
https://linustechtips.com/topic/843149-ryzen-build/#findComment-10522490
