high temps
dpe
howdy y’all, i just recently built my 1st pc, and i have a i5-7600k overclocked to 4.4 ghz cooled by a be quiet dark rock 3, and it’s running under full load in the low 60s. i know this has got to be abnormally high, but what could it be?
intel screwed up the tim on some kaby lake cpus
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
60s under full load is great. I just aim for under 80 when I'm overclocking.
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
I'm just saying, if I was you I'd be pushing that thing further. There's a lot of thermal headroom left.
I'm not a build expert(just built my first pc on monday), but in a lot of the videos I've seen, low 60's have been deemed as good under full load so I'm sure you're fine.
my stock 7600k runs 35 at idle and 60-65 under gaming loads. with a cooler people will generally call "good but not great" but i like the look of it (Cryorig C1)
A.. WHAT?? Who told you 60C is abnormally high for OC'd CPU under full load? Thats really good temps. You have 20-27C of room to OC. High temps under full load is 80C+ with danger levels being 85C+ and too hot being 90C.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
