this was on the homework for my college hardware class. "Suppose a video card requires a 6-pin PCIe power connector, but your motherboard does not have this connector. What can you do to solve this problem without replacing the motherboard?" we all know that a motherboard doesn't power a card with a cable.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/842268-help-answering-a-stupid-question/
Your motherboard wouldn't have a 6-pin PCIe power connector, your GPU would, and your power supply would.
If your PSU doesn't have one, the other option is use a Molex -> 6-Pin PCIe adapter. If doing this, avoid overclocking so you don't overload it.
change the PSU or use those molex to PCI-E adapters
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Trick question? Say just plug in the 6-pin from the PSU.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
thats what I was thinking. this is appearently from an A+ lab book
My Stuff n' Things
It's either a trick question or the makers actually don't have a clue...
I gave it a fun answer eventually. "6pin PCIe on a motherboard!!!, thats witchcraft. BURN IT ON THE STAKE"
My Stuff n' Things
i bet the makers have no clue and they just found the question online
That seems like a way to simple question for  a college class
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
its the intro class
My Stuff n' Things
