help with this front panel replacement product
Solved by W-L,
13 minutes ago, dav1d0 said:what is the usb 2.0 plug connected to the usb 3.0 wire used for if there is already a usb 2.0 plug?
If your talking about the USB interal cable having a daisy chained 2.0 connection to it it's for motherboards that don't have any USB 3.0 headers which allows for the ports to just be used as USB 2.0.
