I basically have a i9 7900x a damn hot cpu currently being water cooled by a  EK XE 360 radiator with a overclock of 4.6GHz at 1.22 voltage. Am currently hitting 86c on Aida64 (CPU,Cache & FPU Stress) with room temp at 25c. My question is adding a 2nd radiator maybe a 420 will i improve on the load temps? I mean if it's like a 2c or 3c improvement i rather just leave it. I know idle cpu temps cannot drop below ambient temperature but my current idle temps are also in mid 30's to high 30's a bit high also.
https://linustechtips.com/topic/841186-more-radiators-better-cooling/
Try to get a 360/240 mm rad. Find the thickest one. And also try getting higher sp fans.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
The more radiators you add, the faster they can rid the absorbed heat from the loop and the longer it takes to reach the max loop temperature.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
and also the maximum loop temperature will be lower
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Not necessarily, you're eventually going to get the loop temp to the same point once the rads are no longer able to diffuse more than what's added.
So around  what max temps should i be seeing if adding another radiator? currently as mentioned getting 86c
You'll likely still get 86C, but you'll be extending the time it takes to get there. I would also make sure that you're getting good contact on the CPU and that your fans are appropriate for your radiators.
Any reason why i should not get a 420? was looking at the EK CE 420 if i do go for a 360 max thickness would have to be 45mm due to limitations of my case. So kinda become 420 or 360 same thickness of 45mm
Extending by how much time? i currently hit 86c within 10 minutes.
That's like saying that if you add more fins to a heatsink, it will only extend the time it takes to get to the same temp, which is obviously not true.
more rad space means lower temperatures. it's the same reason why a 120mm rad can't cool a CPU+GPU loop, but a 360mm rad can.
Laptop:
You'll be lowering temps
I can't tell you exactly by how much, but probably enough to comfortably use your CPU without being close to Tjunction, and maybe squeeze out an extra 100Mhz depending on how much more voltage you need.
Laptop:
