2 minutes ago, Louis_J said:
https://uk.pcpartpicker.com/list/9YtG9W
What do you UK guys think, already have PSU, an SSD and 2 Hard drives, budget is around £1000
-Louis
PERFECTO
but god 1060 IS FUCKING EXPENSIVE
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/840997-upgrade-to-ryzen-build/#findComment-10497742
3 minutes ago, Louis_J said:
Is it worth getting the EVGA SSC version as listed ?
wELL YEAH. BETTER COOLING
Build
https://linustechtips.com/topic/840997-upgrade-to-ryzen-build/#findComment-10497763
Unless you really want the RGB.
Also, which PSU do you have?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£181.00 @ Amazon UK)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (£74.12 @ Amazon UK)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  (£119.65 @ Amazon UK)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  (£77.78 @ Ebuyer)
Video Card: Palit - GeForce GTX 1070 8GB Dual Video Card  (£365.94 @ Aria PC)
Case: Fractal Design - Meshify C ATX Mid Tower Case  (£79.99 @ Amazon UK)
Total: £898.48
Generated by PCPartPicker 2017-09-30 19:18 BST+0100
https://linustechtips.com/topic/840997-upgrade-to-ryzen-build/#findComment-10497806
Total: £898.48
I have a Corsair CX650M 650 Watt PSU, I think the RGB would look pretty good through the tempered glass on the Meshify C also would like to maybe overclock, and not go for too many low tier parts as not on a budget exactly and I want it to be future proof in the sense of maybe getting Zen 2 or something similar on the AM4 platform in the future, thanks for the input :P
https://linustechtips.com/topic/840997-upgrade-to-ryzen-build/#findComment-10497826
All the parts I chose are as high quality. Identical, in most cases. You can overclock with the 1600.
The stock cooler is fine for overclocking to 3,8-ish.
The Prime Plus has the same VRM as the Strix.
Faster memory kit, same manufacturer and dies.
As reputable SSD, with very similar speeds.
And a decent 1070.
Same case.
https://linustechtips.com/topic/840997-upgrade-to-ryzen-build/#findComment-10497845
And a decent 1070.
Same case.
1
Alright will consider, heard somewhere ryzen cant fully take advantage of DDR4 3200 speeds, didnt mean hardware exactly but I want a better aesthetic for the parts not just plain, apart from that thanks man.
https://linustechtips.com/topic/840997-upgrade-to-ryzen-build/#findComment-10497861
