Configuring case for best airflow
Go to solution Solved by WoodenMarker,
18 hours ago, MusicMayne said:
How are the black and white fans that come stock with the Phanteks M Pro tempered glass edition?
I recommend seeing how the stock fans perform before deciding on whether or not to replace them.
Just purchased Phanteks Enthoo Pro M Series TG edition and it comes with 2 Phanteks 140mm fans.
What method would be the best airflow in this case?
two 120 MM intakes and one 140 mm out or
three 120 mm and noctua 140 mm?
Maybe one 120mm on top?
I am all ears.
https://linustechtips.com/topic/840696-configuring-case-for-best-airflow/
I would do at least two in, one out. If you're adding something to the top mount I would also make it an intake.
Reasoning: This should give at the minimum neutral pressure, but should result in positive pressure in the case. Adding a top intake fan would also help draw in more cooler air and push out warm air.
two 140mm intakes (included fans) and one 120mm or 140mm exhaust (if it fits) either an RGB fan or a regular fan + a Phanteks Halo LED ring (syncs with case lighting)
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
4 hours ago, M.Yurizaki said:
4 hours ago, Shiv78 said:
Alright will go the route of 2 intakes and 1 exhaust.
How are the black and white fans that come stock with the Phanteks M Pro tempered glass edition?   ( 2 140mm Phanteks come stock with case)  Decent airflow?
or
Buy 3 Noctua 140mm fans (which 140mm fan model do you recommend?)
