Help with LineageOS
Go to solution Solved by TrigrH,
2 minutes ago, Batteries Included said:
Restarted again and now I am installing the zips. Done in about a min.
you did wipe the phone first right? (in twrp)
the os goes on first then the gapps
dont reboot till you have done both.
have you unlocked the bootloader?
adb reboot bootloader
fastboot devices
fastboot oem unlock <code here>
fastboot oem get-bootinfo
(make sure it says unlocked)
installing twrp:
fastboot devices
fastboot flash recovery C:\adb-fastboot\platform-tools\twrp-3.1.1-0-kiwi.img
unplug phone
Hold Volume Up and the Power button. Continue to hold buttons until the “Honor” logo appears, then release all buttons
after that is successful, make sure you have the rom and gapps on ur micro sd card.
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480616
fastboot devices
installing twrp:
fastboot devices
unplug phone
It says phone unlocked on the bootloader phone screen.
I booted the phone and it looks as if nothing happened.
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480634
so twrp is kinda in basic terms a low level OS which you can use to wipe the phone and install lineage.
to boot into twrp:
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480651
to boot into twrp:
I do not have a microSD. Do I need one?
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480658
you don't but it makes installing lineage sooo much easier.
you only need 1gb of space, are you sure you don't have an old one around somewhere? maybe an old phone has one?
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480667
Found one, let me clear it out. To clarify, do I copy everything from the OS file into the card?
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480674
no.
you need the zip file (dont upzip it)     lineage-14.1-20170920-nightly-kiwi-signed.zip
and you need the gapps zip file: open_gapps-arm-7.1-mini
http://opengapps.org/
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480684
2 minutes ago, TrigrH said:
no.
So after, I put the card in my phone and reboot?
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480690
with those on the sd card you boot into twrp, wipe the phone, install the os then install gapps then reboot.
all existing data is now lost
lineage is now installed
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480694
Don't have it. I have the huawei default recovery
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480709
then this step failed:
installing twrp:
fastboot devices
unplug phone
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480710
installing twrp:
fastboot devices
unplug phone
I tried it a few times and it keeps spitting out
target reported max download size of 266338304 bytes
sending 'recovery' (50048 KB)...
FAILED (data transfer failure (Unknown error))
finished. total time: 11.264s
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480713
Quote
I've got the same problem (different device). In my case, the problem was a faulty USB port in my pc. Just try use another USB port, in my case it solved the problem.
try another port or a better cable
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480777
14 minutes ago, Batteries Included said:
It installed with a new cable, but my device reboots to android 6.0 (normal UI) when I hold power and volume up.
power off the phone, press in both buttons to turn it on
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480838
Same as before, I got huawei recovery
then you must of done it wrong, try flashing twrp 1 more time
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480847
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10480867
52 minutes ago, Batteries Included said:
Right now I see the logo (a circle arc and a dot moving across it) but it seems to be booting forever.
yeah the first boot takes agesssssss
47 minutes ago, Batteries Included said:
Update: Works fine. Thank you!
awesome!
since you have a micro SD card now and twrp is installed you never need to connect to the PC to flash a new rom again.
Just put a new rom and gapps on the sd card, wipe and you are good to go!
https://linustechtips.com/topic/839311-help-with-lineageos/#findComment-10481082
