i have some really noob questions to ask about fans so here i go
1. whats the diffrence between pwm and non pwm
2. whats the diffrence between a 3 pin fan and 4 pin fan
3. can i plug a 3 pin fan onto a 4 pin header on my mobo and still work and still be able to control
4. can i control speeds of any type of fan as long as its plugged in to me mobo
thanks for clearly up my noob questions
https://linustechtips.com/topic/83829-questions-about-fans/
1. PWM (Pulse-width Modulation) means that it will be automatically controlled
2. The 4th Pin IIRC lets the motherboard control the fan.
3. Yes, to control the fan your motherboard needs to have that feature.
4. Again if your motherboard allows you to control the fans.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/83829-questions-about-fans/#findComment-1141320
