Breadboarded PC? WTF? Pictures? Specs?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/837866-some-help-smart-people/#findComment-10465509
6 minutes ago, NinJake said:
You are so very concise and clear with the issue here. We should have had an answer 30 minutes ago!
Seriously though, we need your system specs at the very least to help more, and what does breadboard mean? xD
Sorry I just mean im just firing up the cpu mobo and ram with a screwdriver, thought that was the term used. It's Asus p68 and i5 2500k
https://linustechtips.com/topic/837866-some-help-smart-people/#findComment-10465608
Out of the case that is btw and it'll come on but if I turn the psu off it won't come on for a couple hours atleast
https://linustechtips.com/topic/837866-some-help-smart-people/#findComment-10465610
So the issue, is if you boot up your computer and shut it down, once you "turn on" your pc again it doesn't for ~12 hours?
https://linustechtips.com/topic/837866-some-help-smart-people/#findComment-10465611
Are you SURE you are shorting the correct two pins? It almost sounds like you are shorting power and maybe one of the reset pins? or something bad like that. I don't know why it would take 12 hours to reset itself that in and of itself is strange but I have seen the "it turns on for a second then off" when the power and reset are shorted together.
https://linustechtips.com/topic/837866-some-help-smart-people/#findComment-10465851
