I an trying to build a gaming computer and I cannot find enough information to know if all of these parts are compatible.
Asus x99 II ATX Motherboard 270.61
Corsair Vengeance 16GB RAM*8 2,944.22
Seagate Barracuda 3TB HDD*2 207.82
GTX GeForce 1080*3 1,782.88
GTX 3W SLi Bridge 43.29
Intel Core i7 362.63
Corsair 750w Power Supply 86.59
Corsair Hydro H55 75.76
https://linustechtips.com/topic/837387-component-compatibility-help/
-moved to new builds and planning-
pascal can only do 2 way sli
buy a 1080ti instead of 2 1080s.
what i7? buy used, drop a xeon later down in the line.
where's your SSD?
why a H55? why not a beefier water cooler / a beefy air cooler
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
What
No don't buy any of this
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
a 362$ i7 can't be a x99 one. this seems like a very bad idea of a build. what's your budget? loads of people here will be able to give you a perfectly tailored parts list for you here.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
5820K sells for about that price nowadays
Full Specs
Helios EVO (Main):
Delta - Laptop
dayum. the used market prices only really hit the highend.... a 4790k still kept more of it's value than that
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
Still bad deal, R5 1600X is better
Full Specs
Helios EVO (Main):
Delta - Laptop
oh i'm not saying it's good or bad. just the price drop on that ish
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
poor you. After being a mod that is all i see you do.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
pcpartpicker.com would help.
PSU is undersized for an X99 build with two GTX 1080. (As  @themctipers indicated, gpu only supports 2-way SLI.)
Without knowing the cpu model it is not possible to know if it is compatible with the motherboard.
Without knowing the actual memory kit, not possible to comment on compatibility with the motherboard.
I suspect the H55 is not an optimal choice for a 140W cpu, especially if overclocking is anticipated.
If you follow
Build Plan Thread Recommendations (Please read before posting)
you will get some good suggestions.
Using pcpartpicker.com, a good place to start with a gaming system is a Ryzen R5 1600, R7 1700 or Intel i7-7700K cpu, depending on budget.
  • 2 weeks later...
