I've been searching a lot for the smallest atx case I could find and found realan E-D3 at 23 liters. The case isn't the best but it is windowed, which I like. Does anyone have any suggestions? Money is no problem. Preferred to have window and around 25 liters or smaller. Support for reference cards, or bigger is fine. Thanks in advance.
https://linustechtips.com/topic/836254-looking-for-smallest-atx-case/
Do you mean as in it can fit a ATX motherboard? Or as in it can fit mITX/mATX/ATX/eATX/XLATX (ATX compatible)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Looks like mITX, as thats the case he linked, but it doesnt have a window so it leads me to believe it's not the case hes looking for, as this case is only 11.5mm
If OP is actually looking for a full size ATX, I'd suggest the Riotoro CR1080
