Hello Linus Tech Tips Community & how's everybody doing!
So, I have my DSLR camera and a Rode Stereo Mic. I lower the internal DSLR mic gain to between 35-50%, and then I set the Rode Stereo Mic to +20db. That gives me clean, clear, noise-free audio, excellent!
My question is, is there a reliable, noise-free Bluetooth/Wireless receiver, which will allow me to plug it into my DSLR, then use my Rode Stereo Mic far away for instance with a Bluetooth/Wireless sender?
I understand there are high quality solutions out there like the Sennheiser sets, but I'm not looking for a whole set, including mic, I'm just looking for the wireless capability.
Thanks in advance!
https://linustechtips.com/topic/835760-dslr-wireless-mic-solution-hq/
Just now, Massimo480 said:
Country is USA, and budget does not matter, as long as product is high quality. Again, I'm just interested in sender/receiver, not an additional mic.
Thank you
Ok I don't know of any that will work but maybe @Dackzy has the answer
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
no your going to need a mic with 2.5in inputs
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
As you're using it with a DSLR, I'm guessing you also need it to be portable/battery powered, and as such you need both a stereo transmitter and receiver in a body pack or camera mount style.
By using a stereo microphone this makes it much more expensive as there generally isn't any demand for a body-pack style stereo transmitter, so finding one at any price is already difficult. In fact, I'm unable to find any at all, let alone from a reputable brand. Your only option would be two buy two single channel kits and then split the output from the microphone and then combine the outputs from the receivers to go into the camera. Although this is a bodge and an overly expensive option.
If you were to use a mono microphone, then you would have a wealth of options to choose from, and save money.
You could also get a separate audio recorder (zoom H4...) and record the stereo mic into that, then align the two recordings in software.
