Hello,
I have the Corsair Carbide air 540 case. I like the case because it looks very industrial.
What I don't like abou8t the case is the way they put the 3.5 hard mounts in.
They are hot swappable bays with nothing over the top.
Generally hard drives aren't the most aesthetically pleasing parts ever and here I am looking at a white Seagate sticker all the time.
I want to put something over the hard drive to make it look nicer.
Keeping with the industrial style of the case and everything else, I was wanting to find some passive heat sinks that didn't look stupid.
This was actually a surprisingly difficult endeavor
They could be super tall if they need to be but I would prefer something low profile.
Could I ask the community for assistance in finding something like this.
Alternatively if someone out there has any ideas (other than paint) to cover a hard drive, I'm open to suggestions
Thanks in advance
https://linustechtips.com/topic/834538-hard-drive-covers/
I think it might be a bad idea.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430548
you could make a shroud out of plexi
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430558
Just now, fastcar123 said:
whys that?
Last time i checked my HDD has a huge hole with arrows pointing to it that say "do not cover"
IDK if modern ones still have them
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430562
I believe my WD from 2014 has that. I think its due to thermals and unwanted materials used for the covers.
Tech enthusiast and CS Student
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430576
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430578
they still do, its to equalize the pressure between the inside and the outside.
as long as you dont tape over it, or put something directly on it, he'll be fine.
so creating a shroud would work great, but covering it in electrical tape would be less than ideal
EDIT: i should also mention that it would probably be fine to cover it with tape too honestly.  operating the drive at a different altitude (thus different pressure) than what its sealed at can cause failure, but if you seal it, then never move to a different pressure zone or onto an airplane, its probably fine.
but, If the air pressure is too low, then there is not enough lift for the flying head, so the head gets too close to the disk, and there is a risk of head crashes and data loss.
|Specs in profile|
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430580
Yea and I thought of doing that too. I did that on my graphics card and it works. Ill hold on to that
That's actually a good point that I didn't think about. However looking at my drive I don't actually see one of those holes. Now I realize that it looks weird without it. lol
30 minutes ago, SCHISCHKA said:
I have seen these but these are active. I don't actually need the cooling as my drive never overheats. This is purely for aesthetic.
I never actually knew what would happen if I covered that. Now I do.
Either way I don't intend for a permeant fixture nor do I plan moving anywhere any time soon
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430744
buy a sheet of plastic/metal/wood. put it on top of drive with a spacer. The holes in the drive are just for pressure so you only need a 1mm gap between the cover and the drive. you can get foam double sided tape that is around 1-2mm thick that will do the job
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10430872
You can get HDD silencers basically a chunk of aluminum extrustion that goes over the drive. I've used these before to help keep the system aesthically pleasing when there is just a drive sitting in the floor.
http://www.performance-pcs.com/alphacool-silentmaxx-hd-insulation-rev-2-0.html
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10431400
As cool as that looks, my drive likely woildnt fit into the bay anymore. Still though that matches the look that I'm trying to go for perfectly.
Tjis is probably what ill end so doing
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10432157
Yeah those covers only fit in the 5.25" bays, I personally just have it in the bottom of my case since I don't have 5.25" drive bays. You can always just put the drive in the rear portion of the case if you want to keep things as clean as possible.
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10433554
That us true but the rear of the case has no 3.5 mounts anywhere
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10433564
5.25" adapter to 3.5" drive, or just mount it on a sheet of plexi and a fix it somewhere in the case.
https://www.amazon.com/dp/B005OJFASY/ref=psdc_160354011_t2_B009MGGWQE
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10433572
Yea I could do that. But at that point it would be easier, cheaper, and more convenient to just cover with the plexi
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10433748
     Parts Express has a decent selection of vinyl sheets from VViViD for $20.  These are peel and stick, trim to fit.
https://www.parts-express.com/cat/cabinet-covering/310?N=19864+4294967118+4294961668&Ne=10166&Nrs=collection()%2Frecord[endeca%3Amatches(.%2C"P_PortalID"%2C"1")+and+endeca%3Amatches(.%2C"P_Searchable"%2C"1")]&PortalID=1
Burlwood perhaps?
And some pricey precut pieces from SlickWraps:
https://www.slickwraps.com/devices/cool-stuff/solid-state-drives/samsung-850-evo-2-5.html
samsung-850-pro-ssd_view2_carbon_silver_
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10444384
On 09/16/2017 at 9:23 AM, Defyant said:
Jeff does some great custom covers!
Pretty easy to DIY if you want to have a go your self.
Yea I like that. But I dont have a laser cutter. I would probably just go without a design and have the leds coming out of the sides.
5 minutes ago, Marzen said:
What I think would look really cool is this kinda of vinyl on top of the rgb cover
https://linustechtips.com/topic/834538-hard-drive-covers/#findComment-10444411
