Sound Card for $50
Go to solution Solved by MayflowerElectronics,
Was looking into getting new headphones as well. I want to spend around a 100 but could go a bit more
Take the $50 you were going to waste on a sound card and spend all $150 on headphones. What country do you live in?
Hey guys,
I've heard about the glory of getting a discrete audio card. I'm not a big sound guy but I do enjoy nice clean audio when gaming and listening to music. I'm wanting to know of its worth it to spend $50 on a sound card when I mostly game on my rig and most importantly, which one to get.
Thanks guys!
P.S. I use headphones not speakers
https://linustechtips.com/topic/83419-sound-card-for-50/
Xonar DG/DGX?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136548
Hey guys,
Thanks guys!
You don't need a sound card. Buy better headphones first. I invite you to read the audio FAQ.
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136558
We don't know what headphones the OP has?
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136586
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136605
Unless he has some LCD-2's or HE-500's or some other end-game headphone, there's always room to upgrade.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136614
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136616
I know that.
North America
Ah, you can probably pick up some HD 558's or AD700x (if you have a big head).
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136633
I know that.
That was for the OP. For some reason it still notified you.
https://linustechtips.com/topic/83419-sound-card-for-50/#findComment-1136815
