My hardline custom loop is a few months old and i believe all the air bubbles have been purged. The flow meter, however is spinning slow with a stutter or pause every rotation. Before installing into my system,  I had tested all the tubing, radiators and blocks individually with the flow meter in line. During the testing, the flow meter spun fast and without issue. Idle temp on cpu in an 82f room is 34c. Gpu is 30c. While gaming ,cpu is 55-58c(63c while playing vr) ,gpu just sits at 45c.
Xspc photon x4 reservior and pump combo
Xspc 120 single rad
Xspc 240 dual rad
Xspc razor gtx1080ti water block
Ek supremacy evo cpu block
Thermaltake petg tubing
Thermaltake fittings
Thermaltake flowmeter
Thermaltake c1000 vivid white
https://linustechtips.com/topic/833432-flow-restriction-whats-causing-it/
COuld you give us a picture of the flow meter? Because the temps you are giving while under load are perfectly good for Custom WC loop :) So i think it might be the flow meter that is the problem not the flow. I had bought one myself from ebay (shit one) and it seemed to be working nicely but sometimes it would not spin at all, but i could see the flow.
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
10 minutes ago, alexirv600 said:
-SNIP-
What's your pump speed running at, also those are reasonable temps your system is running at underload, nothing out of the ordinary.
Edited by W-L
@alexirv600, i suspect your loop is fine because the temperatures look fine too, flow meters tend to look as if it is  sputtering or spinning slowly when in fact it is fine. I hate flow meters.
A water-cooled mid-tier gaming PC.
