Just picked up a Gigabyt AX370 Gaming K5. My 5th motherboard for my build (keep switching out). I've come to realize that 16gb dimms won't go past 2400MHz on Ryzen. 5 boards 3 sets of ram no luck.
Anywho, the VRMs are hitting low 90s under stress test. My settings are as follows.
Ryzen 7 1700 @ 3.8GHz
1.4V Core
1.05V SOC
Ram @ 2400MHz
1.35V
CL15
I'd like to hope that the VRMs are good to 125*C but not 100% sure.
https://linustechtips.com/topic/833428-vrm-temps/
1.4V Core
1.05V SOC
Ram @ 2400MHz
1.35V
CL15
1.4V is a little on the higher side for Ryzen if I'm not mistaken and well at 90C if that is on an artificial stress test that isn't unwarranted. It's still safe but for sure on the warm side of things I would try to see if you can lower the voltage a little or ensure good airflow over the VRM heatsinks.
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418236
That sounds high.  What kind of wattage is your CPU pulling?
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418239
Going to test 1.35V and see if it is stable.  Core temps are mid 60's though.
95-105W
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418245
How are you measuring those temps?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418297
4 minutes ago, dave_k said:
Hahaha.
K5 has really trashy VRM. Too bad everyone ignores my guides.
1.4V R7 will fry them, could happen within 2 years, maybe even 1.
Mosfets are fine.
Capacitors are not
I backed it down to 1.35V @ 3.7GHz.
Just read over your guide and while its okay, the x370 Prime from Asus is absolute garbage.  Had 3 of them, tons of issues.
Board sensor.
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418298
A VRM setup that can't handle 105w is completely rediculous.
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418300
5 minutes ago, Snaeb said:
During gaming my VRM's are in the low 60'  so I should be good at 1.35V.
Board sensor.
Prime B350 Plus has way better VRM.
Dont know how about other features.
60°C should be fine
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418317
1.4V Core
1.05V SOC
Ram @ 2400MHz
1.35V
CL15
tbh id lower the vcore. a cpu like the 1700 is very good and will likely last you for several years. 1.4 wont kill it but youre likely sapping a few years from it
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418326
1.4V Core
1.05V SOC
Ram @ 2400MHz
1.35V
CL15
Expected Gigabyte VRMs run hot even their top in board loses to ASUS and Asrock hell even MSI titanium which yeah i know the Titanium is much more expensive but everyone knows MSI uses crappy NIKO.
90C is fine under stress however also 1.425V is fine according to Robert Hallock from Amd. Don't worry about it i bet by the time the CPU starts to die you wouldn't want it any longer anyways meaning it would take 7-10 years before anything bad happens.
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10418349
Board sensor.
PS: Asus Prime X370 Pro has way way way better VRM. Super efficient and very powerful for $150
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10419155
The amount of headaches I had with 3 of those boards was not worth it. I even had one that wouldn't boot with a Ryzen 3 or 5 installed. Had one that wouldn't overclock if I changed the multiplier it got stuck at 1.5GHz. Lastly I had one that wouldn't boot with 32gb of ram. It's probably a good board but had issues like no tomorrow.
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10419261
1.5GHz bug is on everything.
32 gigs is generally shit combination for Ryzen
https://linustechtips.com/topic/833428-vrm-temps/#findComment-10419268
