Just now, 0988ak said:
Well... I need at least a 750 power supply with 4x 8pin connectors for video cards. It has be to be a reputable brand such as Corsair EVGA etc... Make it as cheap as humanly possible.
HEALP
Location, budget?
You almost never get "cheap" and "reliable" at the same time.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/833327-help-me/#findComment-10416961
HEALP
What are you powering and why did you buy two graphics cards and not properly allocate money for two graphics cards to be powered...?
https://linustechtips.com/topic/833327-help-me/#findComment-10416989
Seeing as how you are either an avid 4 way sli gamer or an etherium miner, you will need about 800w just to power 4 480s or whatever you are using so its gonna be at least $100 and over $120 if you want 1000w+ with reliability but here https://pcpartpicker.com/product/jWFXsY/seasonic-focus-plus-gold-850w-80-gold-certified-fully-modular-atx-power-supply-ssr-850fx 850w and $100. If you need 1000w+ https://pcpartpicker.com/product/bcTrxr/evga-power-supply-210gq1000 or https://pcpartpicker.com/product/PfjWGX/seasonic-prime-gold-1000w-80-gold-certified-fully-modular-atx-power-supply-ssr-1000gd
https://linustechtips.com/topic/833327-help-me/#findComment-10416992
Will (6+2) still mean its going to be able to stay stable or do I need adapters?
6+2 means it's either a 6 pin or an 8 pin. If you only need 6 pins then you just leave the other two dangling.
Prior Build Log/PC:
https://linustechtips.com/topic/833327-help-me/#findComment-10416998
Right but it wont take away reliability right?
No, it's built with the fact that you'll probably be using them as 8 pins in mind.
Prior Build Log/PC:
https://linustechtips.com/topic/833327-help-me/#findComment-10417006
29 minutes ago, 0988ak said:
I didn't buy a thing. I'm trying to do budget it out to prevent JUST THAT
Again, what are you powering?
https://linustechtips.com/topic/833327-help-me/#findComment-10417117
