https://pcpartpicker.com/list/YgjZpb < The build I'm going to get.
Will everything pass? it's my first time buying pc parts and building all help is needed!! since I don't want to screw up anything and spend all my money for nothing :[
Thanks!. Oh Btw its a budget build, I'm not rich ;] xD
-Spytra
https://linustechtips.com/topic/832370-need-help-with-pc/
Everything passes, but there are a few things you should change:
-Get 1x8GB of RAM. your motherboard only has 2 slots, so if you ever want to upgrade to 16 in the future, it's cheaper to buy another 1x8GB kit than to get a full replacement.
-Remove the cooler. you don't need an aftermarket cooler, since the stock cooler is more than enough. especially since you won't be OC'ing.
-No SSD is fine for now, but partition your HDD into a 200GB section, and a 800GB section. that way if you ever switch, it's much easier (install games on the 800GB section, and the OS on the 200GB section.)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10407968
you could also get this PSU:
https://pcpartpicker.com/product/Q7L7YJ/corsair-cx-2017-450w-80-bronze-certified-atx-power-supply-cp-9020120-na
450W is more than enough, and it's cheaper by a bit.
maybe try for 16GB RAM with the money you saved?
Laptop:
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10407973
PCPartPicker part list / Price breakdown by merchant\
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($156.08 @ OutletPC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($71.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (1 x 8GB) DDR4-2666 Memory  ($65.99 @ Newegg)
Storage: SK hynix - SL308 120GB 2.5" Solid State Drive  ($62.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.87 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card  ($204.98 @ Newegg)
Case: Corsair - 300R ATX Mid Tower Case  ($35.09 @ Amazon)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($33.98 @ Newegg)
Monitor: AOC - I2269VW 21.5" 1920x1080 60Hz Monitor  ($79.99 @ Amazon)
Total: $756.84
Generated by PCPartPicker 2017-09-08 10:55 EDT-0400
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408003
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.19 @ SuperBiiz)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  ($69.99 @ Amazon)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($84.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB G1 Gaming Video Card  ($174.99 @ Amazon)
Case: Corsair - SPEC-02 ATX Mid Tower Case  ($59.89 @ OutletPC)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Amazon)
Monitor: Acer - G246HLAbd 24.0" 1920x1080 60Hz Monitor  ($119.99 @ Amazon)
Total: $802.90
Generated by PCPartPicker 2017-09-08 11:04 EDT-0400
This is what I would do. Ditch the cooler and get an R5 1600 with an overclockable motherboard.
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408043
13 minutes ago, Spytra said:
https://pcpartpicker.com/list/pZMb3F Hi changed some stuff please check it now!
try this:
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ B&H)
Case: Rosewill - FBM-01 MicroATX Mini Tower Case  ($18.99 @ Amazon)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($37.99 @ Amazon)
Total: $800.98
Generated by PCPartPicker 2017-09-08 11:23 EDT-0400
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408132
Get a 1060 instead of the 1050 and 1x8GB ram over 2x4GB,
And,
"Oh Btw its a budget build, I'm not rich ;] xD"
Don't say that because a lot of people work hard and wait to get the budget for them to build their own PC so it's not only the "rich" people who get good PC's, what you said devalues the work that people put towards their PC.
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408273
And,
I don't think what he said devalues what work people put into getting their PC that's ridiculous also when someone is trying to stay on a budget upgrading the GPU is not needed at all a 1050ti is fine and great for the price.
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408338
i noticed you added a 60hz Monitor if you can spend a little more this one https://www.amazon.com/Acer-GN246HL-Bbid-24-Inch-Display/dp/B00KO4518I/ref=sr_1_1?s=electronics&ie=UTF8&qid=1504887356&sr=1-1&keywords=Acer+GN246HLBbid is not that more expensive than the 60hz one but 144hz is not needed so if you don't stay with 60hz :)
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408353
59 minutes ago, Spytra said:
https://pcpartpicker.com/list/47rDYr < the build now
Hey wanted to ask if the motherboard will cause problems, Also changed the monitor like @VillaiNPC said and changed some of the builds, Thank you, everyone for helping.
The motherboard will not cause problems or anything, but that CPU is really powerful compared to that GPU. it will definitely go unused most of the time. this isn't a bad thing, but it just says that you could go for a better GPU instead of CPU.
I transferred some of the budget to the GPU, and made the build cheaper by going mATX.
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB AORUS Video Card  ($284.99 @ Newegg)
Case: Xion - XON-310_BK MicroATX Mid Tower Case  ($23.98 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($187.49 @ B&H)
Total: $864.38
Generated by PCPartPicker 2017-09-08 14:12 EDT-0400
Laptop:
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408747
Total: $864.38
Thank you, dude! can I overclock the CPU?
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408752
Yes, on a B350 motherboard, you can.
it does come with a pretty small stock cooler though (the 1400 comes with a smaller, stealth cooler), but you should probably be able to get a quick 3.8Ghz or so overclock.
one thing I can advise you on, is change the case.
I just remembered that the case I linked is pretty crap, so just choose a different cheap mATX case.
Laptop:
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408759
1 minute ago, Spytra said:
Oh btw do u know any videos that are good for starting pc builders? @RadiatingLight also can u link me a good case for the build? since I don't know anything about computers this computer was built by friends help xD
TBH IDK too much about low end mATX cases.
look up some reviews and pick one that seems like a good fit.
Laptop:
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408776
12 minutes ago, Spytra said:
Yeah that seems great
just don't rely on the rebate to get your costs down. 50% of the time they get denied for funny reasons. think of the $10 as a bonus, not a discount.
Laptop:
https://linustechtips.com/topic/832370-need-help-with-pc/#findComment-10408841
