wrong ram speed
Go to solution Solved by Fessas,
2 minutes ago, rjackdaw said:
does this mean everything is ok? do i need to change anything in the bios or leave everything on its defaults?.. the task manager show that there's supposed to be 4 ram slots but physically it is only 2.. why is that? epeccy and cpuz shows the same things
5 minutes ago, Enderman said:
DDR = Double data rate
800 * 2 = 1600
Your programs show the correct speed.
As enderman said Programs show the correct speed. and dual channel is usually slots 1&3, and 2&4 which is why the screen says dimm1 and dimm3
wrong ram speed in taskmanager and 3rdparty utilities
specs
os 10 x64
rapter 450w
Gtx460
athlon 750k
micron 4gb 16JTF51264AZ-1G6M1
EMX-A55FM2HD-iCafe mobo
BIOS
    Brand    American Megatrends Inc.
    Version    4.6.5
    Date    08/10/2012
i have 1x4Gb 1600mhz Micron memory
I set it on bios in 1600 to make sure its ok.
the rest of the setting are on its defaults
till i found out that the actual speed on taskmanager / speccy / cpuz
shows that it runs on 800mhz.
im no expert when it comes to this kind of thing.
just wanted to know if this a bug or something is wrong in the bios / os setup.
is my system suffering from low ram speed?
https://linustechtips.com/topic/830621-wrong-ram-speed/
800 * 2 = 1600
https://linustechtips.com/topic/830621-wrong-ram-speed/#findComment-10389821
800 * 2 = 1600
https://linustechtips.com/topic/830621-wrong-ram-speed/#findComment-10389828
800 * 2 = 1600
https://linustechtips.com/topic/830621-wrong-ram-speed/#findComment-10389837
ohh.. now that make sense to me... i dunno why but my previos mobo ecs shows 1600 and other programs shows 1600... but if this means that the system ram is ok, i can put my mind and pc at ease.. thanks a lot !!
https://linustechtips.com/topic/830621-wrong-ram-speed/#findComment-10389847
