10 hours ago, flamea said:
Which are best? Which can illuminate from both sides? Can I easily connect 8-9 fans to motherboard via controller? The idea would be to control the colors, effects via motherboard.
For fans that can be controller with the motherboard your options will be very limited, the Corsair and NZXT fans will be controller via their software.
https://www.asus.com/campaign/aura/us/Sync.html
https://linustechtips.com/topic/829930-rgb-fans/#findComment-10385162
