I'm using an ASUS Maximus 8 gene (AI Suite 3) with a swiftech fan splitter to control 6 fans.  For some reason they all only run at max.  It worked perfectly, then I had to move. I reset the CMOS, but I changed everything back to pwm mode.  When you run the fan optimization, they still only run at max. I'm at a loss as to why they wont slow down.  Any ideas?
https://linustechtips.com/topic/829399-cant-control-fans/
is the fan port at pwm mode and the fans are not pwm, or vise versa
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/829399-cant-control-fans/#findComment-10378061
Does the fan splitter support PWM?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/829399-cant-control-fans/#findComment-10378064
You have the splitter (I think I know the one you're talking about; it's 4-pin) connected to a 4 pin fan port on the mobo? The fans connected to the splitter have 4 pins and are PWM? If the previous two questions are yes, then look in the bios for the fan port; sometimes a 4-Pin fan port is set to like "voltage" rather than "PWM" (It should be PWM).
https://linustechtips.com/topic/829399-cant-control-fans/#findComment-10378065
4 minutes ago, radmanhs said:
Forgot to say the fans.  The port is pwm, and they are all Corsair pwm fans. Yes the splitter supports pwm, it all worked before I moved.  I'll take a look in the bios again, I think there was only pwm and DC options
On top of that, (if the splitter is plugged into CPU_FAN port), check to see if your motherboard has an option to set the "CPU target temperature". If so, make sure that temperature is set to like "50 degrees", not "low as possible."
https://linustechtips.com/topic/829399-cant-control-fans/#findComment-10378081
