So I'm kinda on a budget between 1000-1500$ NZD
my requirements are:
Liquid cool
atleast gtx 1060
be able to run most modern game Ez(bdo, destiny2 and pugb)
can u please pick parts using pcpartpicker(nz) that sell at pc lounge or pbtech(close I can go and buy)
thats all thank so much in advance for helping
https://linustechtips.com/topic/828316-need-a-first-build/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($336.00 @ 1stWave Technologies)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard  ($134.00 @ 1stWave Technologies)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($114.00 @ 1stWave Technologies)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($75.00 @ 1stWave Technologies)
Video Card: Gigabyte - GeForce GTX 1070 8GB Windforce OC Video Card  ($732.00 @ Paradigm PCs)
Case: Corsair - Carbide SPEC-M2 MicroATX Mid Tower Case  ($65.00 @ 1stWave Technologies)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply  ($95.00 @ 1stWave Technologies)
Total: $1551.00
Generated by PCPartPicker 2017-08-30 00:07 NZST+1200
You don't need liquid cooling, because the 1600 comes with a decent stock cooler which allows you to overclock it to 3.8-4GHz ;)
The PSU isn't amazing, but it's the only one I could find for a reasonable price :/
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10366902
PCPartPicker part list: https://nz.pcpartpicker.com/list/3VGVNN
Price breakdown by merchant: https://nz.pcpartpicker.com/list/3VGVNN/by_merchant/
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($102.28 @ Ascent Technology)
Video Card: Gigabyte - GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($464.64 @ PC Force)
Case: Silverstone - PS08B (Black) MicroATX Mid Tower Case  ($53.52 @ Ascent Technology)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($157.00 @ 1stWave Technologies)
Total: $1436.44
Generated by PCPartPicker 2017-08-30 00:16 NZST+1200
Liquid cooling is (a) not necessary and (b) your budget is too small for that. Use the stock cooler first and buy a liquid cooler later if you really want one.
Checked what I can do if limited to those two stores, ended up with a 1600 and 1050ti build. Bad idea to limit to those 2.
Desktop benching:
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10366924
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($137.00 @ 1stWave Technologies)
Storage: Silicon Power - Slim S55 240GB 2.5" Solid State Drive  ($125.34 @ PB Technologies)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($75.00 @ 1stWave Technologies)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Turbo Video Card  ($456.00 @ PC Force)
Total: $1465.34
Generated by PCPartPicker 2017-08-30 00:28 NZST+1200
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10366944
https://nz.pcpartpicker.com/list/9YRCxYc It's pretty decent and watercooling isn't needed OCing, an ssd is decent, and prices are expensive in New Zealand
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10366953
Note: changed the Gpu model from blower style to better one, added only 8gb stick of 2666mhz since didnt find anything 3000/3200 mhz. because its wise to go with a single 8gb stick & add another 8gb later. Ryzen has slight issue for overclocking 4 sticks to higher frequency memory.
Memory: Kingston - FURY 8GB (1 x 8GB) DDR4-2666 Memory  ($124.00 @ 1stWave Technologies)
Storage: Kingston - A400 240GB 2.5" Solid State Drive  ($140.00 @ Paradigm PCs)
Total: $1498.64
Generated by PCPartPicker 2017-08-30 01:20 NZST+1200
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10367072
13 minutes ago, ravy said:
Question why micro atx? Because I would like to sli it in the future
mATX boards are cheaper than full ATX boards. In order to support SLI, You would also need an X370 chipset, driving up the cost even more. Also, the 1060 doesn't support SLI.
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10369103
Would u say that this would work?https://nz.pcpartpicker.com/list/
Edited by ravy
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10369160
For SLI? No. The motherboard doesn't support it, and I wouldn't want to run two GPUs off of a single daisy chained cable. In any case, multi GPU setups are falling out of fashion, with less support from Nvidia, and as a single high end GPU tend to be good enough.
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10369300
Ok thanks imma get the first build than
https://linustechtips.com/topic/828316-need-a-first-build/#findComment-10369352
