So my friend has a pc with a i5 and a rx 470
And I have a Ryzen  1700 and a 8gb rx 480
he's running Minecraft at 200 to 150 fps and I'm stuck at 56-60
I have 12 gb of ram  gave Minecraft 4gb this isint the only game my fps is lower than his I need help anyone that can help
https://linustechtips.com/topic/828178-fps-issues/
same settings?
Desktop benching:
https://linustechtips.com/topic/828178-fps-issues/#findComment-10365654
What resolution?
5 minutes ago, Nicholas12354 said:
yes everything is the same
So people know that you aren't ignoring them try to mention them like @ or quoting them by press the arrow that's facing to the left below the text
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/828178-fps-issues/#findComment-10365725
5 minutes ago, Billy_Mays said:
What resolution?
same I it's default I mean it's Minecraft lol so I'm sure it's 1080 not 4k
https://linustechtips.com/topic/828178-fps-issues/#findComment-10365753
Do you have back ground processes and low usages?
https://linustechtips.com/topic/828178-fps-issues/#findComment-10365776
It sounds like VSync is on. Make sure thats off in your game settings as well as AMD Settings theres an option.
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
https://linustechtips.com/topic/828178-fps-issues/#findComment-10365781
