Combining Bands into One SSID?
Rezalis
I recently bought this router Amazon Link while it was on sale and it has three bands. I have currently set up the system using each band (2.4, 5, 5) on a different SSID. If I were to set the SSID of each band the same along with same password, would I still receive take advantage of having three bands? Or will the router only connect the devices to one band?
Nope, you can't do that.  Dual 5Ghz bands are retarded IMO and mostly a marketing gimmick to inflate the "total speed" figure.
Workstation:  14700nonk || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 9900nonK || Gigabyte Z390 Master || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
If you do that, whatever device is being used will connect to the strongest signal it "hears".
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Is a tri-band router really worth it then? I was looking at the Google mesh system and I feel like that might be better for low-latency games. Link
The other thing to look at is you cannot mix standards on the same device connection. For that unit it has 2x 5GHz [11an+ac] and 1x 2.4GHz [11bgn] however if your device is connecting on 802.11ac then you cannot have that same device connected at 802.11an at the same time.
Where a tri radio device is good is when you have some older devices that might only be 802.11n spec as well as some newer 802.11ac devices. On a single 5GHz radio device that would mean your entire network would fall back to 802.11n to allow for the older device. On a dual 5GHz radio device this means only one radio needs to be on 802.11n the other one can be on 802.11ac.
On most consumer devices you need to manually deal with the connections using different SSID's. If you set them all to the same SSID then its random which it will connect to.
If you have a better device (think enterprise) then they will use something called band steering. This is where the router will control which device its connected to based on which will give the best over all stability and speed. You set one SSID and the router deals with it all. For example, Aerohive Wireless or Ruckus Wireless.
