PSU help!
Go to solution Solved by aisle9,
24 minutes ago, rx93 said:
https://pcpartpicker.com/list/L96qvV
Im using this build with a SeaSonic M12II 520W PSU. The system should be drawing about 450W under load. will this PSU do the job or do i need to upgrade asap?
*not planning on OC the system till i swap psu, just wondering if this will do the job for a couple months.
The thing about Seasonic PSUs is that they are damn good PSUs. Case in point: I have a system with an i7-6700 and, once upon a time, a Sapphire HD 7970 that consumed 300W by itself. The total system draw was around 500W, and I had almost that exact PSU, an M12II EVO 520W. Not only did the Seasonic PSU never once have a problem, even under stress testing loads, but when I tried the 7970 in a different PC with an EVGA "600W" PSU, it wouldn't even post until the 7970 was removed.
Moral of the story: you're fine. If a Seasonic PSU says it can handle 520W, it can handle 520W.
https://linustechtips.com/topic/827756-psu-help/
You should be fine. Most of the PSU wattage calculators overestimate by a lot in order to profit more and keep your components safe.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/827756-psu-help/#findComment-10361406
Just now, rx93 said:
is there a risk to the gpu or other hardware? I would think low chance of risk
I see no problem with running a 7 year old 520w power supply at almost 100% of it's possible output , that'll go real well.
Just make note of when you initially start using it and when it blows up so we have a good timetable for how long a using the wrong power supply actually lasts.
https://linustechtips.com/topic/827756-psu-help/#findComment-10361425
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/827756-psu-help/#findComment-10361446
