Hi,
I'm looking to build my first PC and wanted to get some advice. So far i have two lists of parts that i'd like your opinion on but i haven't put any fans or cooling systems in as i didn't know what to get.  The lists are fairly similar, i've mainly just upgraded the memory and SSD drive in the second and as the first list better suits my budget i'd really like to know how you think it will perform and if you think it would be worth it to upgrade to the second list.
I'll mostly be using the system to watch T.V and DVD's, play games (i'm looking to replace my xBox with the computer), edit photos and video clips as well simple word processing tasks and i'd like the system to be fairly quiet.
I haven't built a pc before so if you know of any sites or threads i should look at, please let me know. I'd also like to know what anti-virus i should get for when the PC is up and running.
Thank you very much for your help, i really appreciate it.
These are my lists:
List 1
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
Motherboard: Asus Z87-PRO ATX LGA1150 Motherboard
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
SSD Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Disk
HD Storage: Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: Gigabyte GeForce GTX 770 2GB Video Card
Sound Card: Asus Xonar DGX 24-bit 96 KHz Sound Card
Case: NZXT Phantom 410 (White) ATX Mid Tower Case
Power Supply: Corsair Enthusiast 850W 80+ Bronze Certified ATX Power Supply
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Operating System: Microsoft Windows 8 Professional (OEM) (64-bit)
List 2
Memory: Corsair Dominator 16GB (4 x 4GB) DDR3-1866 Memory
SSD Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Disk
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer
https://linustechtips.com/topic/82743-first-build/
In my opinion, if you're playing games you should go with Windows 7 just because of driver support which Windows 8 still lacks. Also, you should get a good cpu cooler so that you can overclock your i5 and get more performance out of it :)
https://linustechtips.com/topic/82743-first-build/#findComment-1129092
So the differences are more expensive RAM, more expensive SSD and different optical drive for some reason... well depends if you want to waste extra money or not.
Go with the first build, and use the difference to pay for better cooling. Also, dunno why you think you need 850W. Get a better 600W PSU.
I'd grab this power supply for a single card overclocked to high hell:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256086
or the 750W model for two cards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256079
Both feature fully modular cables which will be excellent to sleeve to make you build look a lot nicer.
Other good options:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171080
http://www.newegg.com/Product/Product.aspx?Item=N82E16817580009
And AVG free seems to work fine.
Another thing: unless you specifically like the gold look of the Asus Z87 boards, there are a lot of other choices, black and red/orange/green/yellow - you decide. Any Z87 board from Asus, MSI, Gigabyte or AsRock will do the job.
Current rig: i5 4670K | GTX 670 | Asus Z87I-Pro | Silverstone Strider Plus 600W | Custom mITX case | Seagate Barracuda 3TB | Samsung 840 120GB | G430 | CM Storm Quickfire Pro - MX Red | LG 21.5"
https://linustechtips.com/topic/82743-first-build/#findComment-1129095
List 1
List 2
i would just change the gtx 770 to an r9 280x and call it a day. both lists will be fine.. for cpu cooler grab a hyper 212 evo. as for fans any static pressure optimized fans
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/82743-first-build/#findComment-1129099
list 2 seems like a better one to go for, BUT OH MY GOD DONT GET A SOUND CARD. if you want to enhance your audio, get an external Fiio Olympus E10 DAC.
LOOK AT MY TUBE, MY TUBE IS AMAZING. DONT LICK IT IT DOESN'T TASTE LIKE ANYTHING. IT DOESN'T HAVE A MANE OR PENIS EITHER. SHUT UP.
https://linustechtips.com/topic/82743-first-build/#findComment-1129893
The lists aren't that different at all.
Best anti-virus is common sense. In other words, you don't need one. Just don't click on links to sexy singles in your area waiting to meet you.
https://linustechtips.com/topic/82743-first-build/#findComment-1133189
Thanks for the input guys. I've narrowed down my list of componants but are still having some trouble deciding between certain parts. Please let me know what you think.
Also, I currently have a BenQ GL2450Hm monitor but am considering getting a BenQ XL2420TE 144hz monitor or a Dell UltraSharp U2412M monitor. Has anyone had any experience with these monitors? And what are your opinions of them?
Thank you.
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-Z87X-UD3H ATX LGA1150 Motherboard or Asus SABERTOOTH Z87 ATX LGA1150 Motherboard
Memory: Corsair Dominator 16GB (4 x 4GB) DDR3-1866 Memory or Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory
SSD Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk
Video Card: Gigabyte GeForce GTX 760 4GD or Gigabyte GeForce GTX 770 2GB Video Card
Case Fan: Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm  Fan
Power Supply: Corsair Professional 850W 80+ Gold Certified Semi-Modular ATX Power Supply
What would be the difference in performance if i used the different motherboard, rmemory and video cards?
https://linustechtips.com/topic/82743-first-build/#findComment-1138945
Around $1500
What currency are you using?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/82743-first-build/#findComment-1143466
Around $1500 AUD
My recommendations: http://au.pcpartpicker.com/p/2eFOD
https://linustechtips.com/topic/82743-first-build/#findComment-1143583
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($265.00 @ PCCaseGear)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard:  Asus Z87-A ATX LGA1150 Motherboard  ($199.00 @ CPL Online)
Memory:  G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($99.00 @ Mwave Australia)
Storage:  Samsung 840 Series 120GB 2.5" Solid State Disk  ($105.00 @ Scorptec)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($98.00 @ CPL Online)
Video Card:  EVGA GeForce GTX 760 2GB Video Card  ($319.00 @ PCCaseGear)
Case:  NZXT Phantom 410 (White) ATX Mid Tower Case  ($125.00 @ Mwave Australia)
Power Supply:  SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($129.00 @ PCCaseGear)
Optical Drive:  LG GH24NSB0 DVD/CD Writer  ($22.00 @ Mwave Australia)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($108.00 @ Mwave Australia)
Total: $1508.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-12-04 15:39 EST+1100)
https://linustechtips.com/topic/82743-first-build/#findComment-1143698
