Mini Itx vs Atx PC cases
Go to solution Solved by Mike Soda,
9 minutes ago, Ssg6129 said:
any cases
I had to look under the non-gaming catagory but found this, without side windows & not all come with removable filters which I would've preferred.
https://www.newegg.com/Product/Productcompare.aspx?CompareItemList=7|11-119-274^11-119-274%2C11-139-044^11-139-044%2C11-352-032^11-352-032
I vote for mATX, smaller then ATX but not as cramped as Mini.
Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3
Just now, Ssg6129 said:
any cases
Well I have a CoolerMaster MasterCase Pro 3, it's on the larger side of mATX form factor though. 2 other things I don't like are the gaps between top handles & dust filter. Other than that though it was very easy to build in, front IO cables were just long enough for me to connect everything outside the case for testing. Unfortunately I'm not seeing much else on Newegg right now unless that's just their sorting messing up again.
any cases
Edited by Mike Soda
had wrong link, opps lol
13 minutes ago, Ssg6129 said:
any cases
I picked up a Thermaltake Core V21 MicroATX. It is by far one of the easiest mATX cases that I've worked with. Every side panel, the top, and the bottom can be taken off for easy cable management and component accessibility.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
That's a good one too it's just I personally avoid that brand at all costs. Didn't like how they copied some of Fractal Design's cases & their just cheap quality in general especially with cooling solutions.
I don't necessarily like Thermaltake as a brand, but I do have to say that this case is very well built. I did have to pick up a Be quiet! BL067 to get suitable cooling for my GPU. Thermaltake almost made it a requirement to get a rear fan, since they have an empty spot begging for a fan.
Desktop
Homelab
Someday I want to design my own case, internal layout of MasterCase Pro 3 but smaller. Foldable or retractable handles like the Corsair Vengence C70 but lower profile top dust filters like Fractal Design, just not magnetic hate those lol.
