Hey all! I'm almost ready to purchase my parts and put it all together, just have some last questions (this one and some more in Air Cooling)
My motherboard lists the factory-set speed on my chosen RAM (1866) as an overclock speed. Will the system probably be stable at 1866 or will I have to fiddle with the RAM speed/timings? I'd like to not have to mess with this to get my system running since I've never had to change memory settings before; I really have no idea at present how it works or how to not brick my system XP
System specs:
http://pcpartpicker.com/p/2bBtJ
https://linustechtips.com/topic/82703-first-build-memory-question/
So are you saying that the ram will work with little to no need for interface on my part?
It depends.. is your ram 1866 speed? if it's under or at 1866 speed you'll be fine, if it's over it should automatically clock it down if im not mistaken.
Heaven's Society - Like Anime? Check us Out Here!
Ok, thanks. My ram is Ripjaws Z which does come at 1866. Would you recommend switching to ram that wouldn't be downclocked, or should I just stick with what I have now and overclock when I feel more confidant about it?
EDIT: Sorry, didn't see the "or at" in your post, my question is now pointless XP
If you bought an 1866MHz memory and you see that it automatically went 1866MHz, there's no problem :D
CPU: Intel Core i5-4670k Mobo: MSI Z97 Gaming 3 RAM: Crucial Ballistix Tactical Tracer 8GB 1866 Video Card: MSI GTX 970 GAMING 4G SSDSamsung 840 Evo 250GB HDD: WD 1TB + 500GB Caviar Blue
PSU: EVGA SuperNOVA 750W G2 Case: Gigabyte GZ-G1 Mouse: Corsair M65 RGB Keyboard: Corsair K70 MX Brown MousePad: Corsair MM200
Steam/Origin/Uplay: renz62
If you are going to use XMP then it'll be stable. Overclocking manually may result unstable situation and need for adjusting timings. But I would suggest either getting 1600MHz or going for 2133MHz if you want higher speed on RAM. Difference between 1866 and those under and over are so minimal.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
