So I more or less just need a verification saying that what I'm getting isn't ridiculous in any sense and that I appropriately chose all my components for my use case. I'm not planing to overclock my system, I just want the max performance of WQHD gaming. The games I play are Ashes of the singularity, Dark souls, and DOOM. I mainly chose components to be better than what I currently own: I'm running a AMD A10 6800k along with 2x8GB of DDR3 ram and a 1050ti to run my graphics. This system serves me well, but is incredibly outdated. I made beginner mistakes with that build which I don't want to do again. Please let me know if there's any problems and please feel free to ask any questions that you may have for me! Thank you so much for taking the time to read my post!
WQHD
Here's what I got so far:
CPU / MoBo
A combo pack including both a Ryzen 1600 and a ASUS PRIME B350-PLUS
https://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3482348
GPU
EVGA GeForce GTX 1080 Ti Black Edition
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487375&cm_re=geforce_gtx_1080_ti-_-14-487-375-_-Product
RAM
G.SKILL Aegis DDR4 16GB (2 x 8GB)
https://www.newegg.com/Product/Product.aspx?item=N82E16820232251
PSU
CORSAIR TX-M 650w PSU
https://www.newegg.com/Product/Product.aspx?item=N82E16817139207
Storage
WD Blue 1TB
https://www.newegg.com/Product/Product.aspx?item=N82E16822236339
Case
Corsair Carbide SPEC-04
https://www.newegg.com/Product/Product.aspx?item=N82E16811139095
(I'm also getting after market case fans which I haven't included in this list. As I said at the top, I will not be overclocking however I would like my overall system to be adequately cooled.)
https://linustechtips.com/topic/826249-new-build-help/
2k? or do you mean 1440p? What 1440p monitor do you have?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/826249-new-build-help/#findComment-10344616
By 2K you mean 1440p? 2K is technically 2048×1080, a cinematic 1080p. Looks good, though could save with a 1070/1080 if just 60hz. Perhaps also an SSD if you dont already have one.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/826249-new-build-help/#findComment-10344617
I meant WQHD or 2560x1440. I do not currently have one but I plan to get https://www.newegg.com/Product/Product.aspx?item=N82E16824236466 or an equivalent. As of right now I'm running on a 1920x1080 TV.
https://linustechtips.com/topic/826249-new-build-help/#findComment-10344693
Sorry, I mean I'm getting a WQHD 144hHz monitor. A cenimatic 1080p is exactly what I want. I don't want or need 4k. I'd also like the the 1080ti so I can max out most settings in WQHD at 100Hz+.
https://linustechtips.com/topic/826249-new-build-help/#findComment-10344709
