hey.
so i've been googling and saw that adobe premiere does not handle shadowplay videos well because of the variable framerate. so audio gets out of sync.
right now im using vegas but i HATE it. render times are almost 2X slower than in premiere. i wanted to know what do you guys use or what can i do so i can edit using premiere?  I've read that you can just encode the videos in handbreak so the video wont be variable frame rate so premiere wont go nuts with the audio but that just defeats the purpose having the spend time encoding it in handbreak then in premiere. would just end up using the same amount of time if i just used vegas.
has anyone have any lucky with davinci desolve? or what other programs could i use. (i dont have a mac or able to turn my rig into a hackintosh so final cut pro is not an option)  Should i just ditch shadowplay all together and use OBS? I used to use RTSS (msi afterburner) but everytime i used it. performance hit was a little more than shadowpay (even when using the Nvidia api for recording) and video's would come out looking jerky and not smooth. like some sort of frame pacing issue while recording? idk)
any help would mean a lot. just want to stop having to use vegas being that render times are horrid
https://linustechtips.com/topic/826248-need-help-with-shadowplay-adobe-premiere/
3 minutes ago, Valkyrie743 said:
hey.
Yes I have been using Premiere Pro and Audio gets out of Sync so I stopped using it. Using Vegas and it does it well
Cant you just make Shadowplay not variable?
For out of sync audio I would blame Shadow Play, not Premiere.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
i wish i could. not really blaming anyone per say. each has their own issues. premiere should work on variable frame rate video files and fix it. and shadowplay should give users more options. also i get horrid video stuttering as well. My shadowplay cache disk is ramdrive i made and still have issues with video pauses with high bit rate option selected. even at 50 Mbps i sometimes get video stutter or pauses with my recordings. i want to be able to record game clips at 100 Mbps (i play at 1440P). but im just fighting this one issue for now.
