Some questions about mining.
Solved by MainDisco,
i would just mine ethereum.
yes, these wallets can be hacked, like email adresses. just look around the internet for some good wallet providers.
It should make some money with even 2 1070. Just set a miner up look at your hashrate and then use this calculator https://www.cryptocompare.com/mining/calculator/eth
to see how much profit you can make.
There is no way i know of to go around the mining fee.
Im using the nanopool ethereum pool right now https://nanopool.org/ there is also everything discribed how you set your miner up, including the softwear.
