hello, I'm planning on building my first budget gaming pc,
but now the first trouble appears selecting parts I have already listed some parts but I have some questions.
like can I bring my old DDR4 memory and/or if the system will even work.
I live in the Netherlands and my budget is around €1200/€1300.
so I hope that you could give me advice or say if the system is even compatible.
I appreciate your time, greetings Rick
ask me about your system builds, AIO's, CPU's, PSU's, and GPU's.
https://linustechtips.com/topic/825509-rookies-first-pc-build/
it's dutch or from belgium i recommend using the website Azerty in if you're from the netherlands (im ofcourse not related to this site in any way)
it had cheapest prices on most items free shipping 1 day delivery great support, you can even pick up the hardware if you live nearby like me,
I could help you with your specs if you tell your budget, i can also explain something to you in Dutch if you don't understand something
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336779
Doesn't Belgium speak French or German?
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336783
They speak Dutch and French. I don't know about German..
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336788
6 minutes ago, Bartb56 said:
no north part in belgium is french south part speaks dutch as far as iknow but they're lomda weird ;)
other way around, is also more logical if you look the the map
also for the op, get a cheaper 1060 6gb and get a normal ssd instead of the nvme one, you can get 250 GB for that money
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336809
woops mixed those 2 up :P but appearently a part does speak french
https://gyazo.com/f15bf9338910aa59e20f8682418e39c7
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336814
19 minutes ago, ricksteendam1 said:
i'm from the netherlands (utrecht) my budget is max €1200
definitely check tweakers for the lowest prices and remember to quote people using the button below someone's post
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336886
31 minutes ago, Rekted said:
7700K + Z270 + 360mm AIO
Either you're very rich or you misunderstood the word "budget"
I think I misunderstood the word budget. but it is still in my budget
https://linustechtips.com/topic/825509-rookies-first-pc-build/#findComment-10336912
