Is 520W really enough to power my system?
gtx 1060 3gb zotac.
I5 7400
Ripjaws 8 gb
I've been experiencing sudden shutdowns lately and got frustrated, removed my videocard and the sudden shut downs disappeared. I currently have Seasonic s12 520W.
please enlighten me what to do next. should I buy another psu or is there a remedy for this ( tried to disconnect the other fans of my case aswell, didnt worked)
https://linustechtips.com/topic/824472-psu-help/
Well, I've seen systems with 1070s and i5 7600ks using similar sized PSUs, so I don't think it's a problem with power capacity.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/824472-psu-help/#findComment-10325549
ya you will be fine you would even be fine with a 450 watt
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/824472-psu-help/#findComment-10325563
However, with the case of the random shutdowns being solved by removing the GPU, that's pretty odd.
My PC:
https://linustechtips.com/topic/824472-psu-help/#findComment-10325564
520W is more then enough.
my 4770K and GTX 1070 system rarely pulls more than 350W.
I'd assume that this is either a hardware fault in the GPU, or maybe something in software is causing it to shut down.
also, it's not triggering overcurrent protection, right? (when the PC shuts down, it doesn't need to be unplugged fully before turning on again, right?)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/824472-psu-help/#findComment-10325574
yep it doesn't need to be unplugged, any suggestions?
https://linustechtips.com/topic/824472-psu-help/#findComment-10325761
