I installed a program called Moonlight on my apple tv using this guy's tutorial. It is basically a way that you can use nvidia gamestream on the apple tv. When I put in the pin that it gives me into gamestream Moonlight says that the pin is incorrect, when infact it is correct. Everything works fine when using Moonlight on my iphone. It hurt using a mac to do this.
Build:
Intel Core I7 6700k (clocked to 4.6ghz)
Patriot Viper 3000mhz ddr4
ASUS maximus 8 hero (I hate this mobo)
Evga gtx 1080 superclocked
250GB Samsung 850 evo
2tb WD Black 7200rpm
Ek watercooling kit a240g with 360 expansion pack
Primochill Vue Red fluid
Corsair Graphite 600t (white)
You thought "Gee, Donald Trump sure has a great build!"
https://linustechtips.com/topic/824241-nvidia-gamestream-incorrect-pin-issue/
1 hour ago, manikyath said:
from experience, moonlight is VERY finnicky, just trial & error settings until it magically works.
There aren't any options to change.
Build:
