First PC Build HELP
Go to solution Solved by NoLoMo,
38 minutes ago, stealth80 said:
I appreciate it is over budget, I'm just stating that BDO doesn't scale well with cores, but your usage is a good match for the 12 thread 1600. I'm not sure why you would say a 7700k is overkill when a Ryzen 1600 is 2 more cores/4 more threads ;) - Your build looks good, with the money you saved on windows I would look at a different PSU and possibly a bigger SSD. Also keep in mind if you want to SLI then you need an X370 board, the B350 only offer crossfire.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.65 @ OutletPC)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($111.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($126.99 @ Newegg)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($99.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($464.98 @ Newegg)
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair - RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1158.34
Generated by PCPartPicker 2017-08-18 18:07 EDT-0400
Ahhh I see, well as long as I can play BDO at a reasonable frame rate it should be fine. Which PSU should I go for another corsair or would that change?
Hello I am building my first PC ever and just wanted some opinions on the matter. Ideally my budget would be 1K included the OS but will be willing to slightly go over if I must. The current plan I have is: https://pcpartpicker.com/list/6DHZYr and as per recommendation I was thinking of swapping GTX 1060 for a used 980ti but I didn't find much on Craigslist. As far as case fans go I have two Noctua NF-F12 PW LTT edition cooling my laptop I can use for the case; will it be enough? This will mainly be for school but like any normal person I will game on the occasion (Black Desert is probably my most intensive game). As far as content creation goes, I do photo edit/video edit quite often and as far recording as long I can play and record at a decent quality I am fine with it. Last thought, I got used to having two monitors (my laptop screen being one of them) is there any cheap $30 monitor I can pick up? I already have a decent IPS monitor, or so I like to think.
https://linustechtips.com/topic/823812-first-pc-build-help/
https://pcpartpicker.com/list/2HczD8
I fixed the build that you had before, and if you need windows just download it onto a usb and I might possibly have a windows key lying around here
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10318962
Thanks, I see you switched the MOBO, RAM and case any reason as two the first two?
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10318994
One I dont really trust MSI reputation on most things, asrock has pretty solid mobos, other than asus and a few others I having the Asus Crosshair VI with a 1700. I would choose the asrock for a b350 if I had to go with one, the ram was not lpx or flare or anything amd compatible right now so you would be stuck with 2133 mhz ram like I am for now, and the case the one that you had aesthetics wise didnt look smooth phanteks and few other companies have cheap options but wont downgrade air flow etc
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319006
Ahhh I see, ok so if you did have that windows key lying around how much would you let it go for?
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319016
Are you only trying via xmp? Is your bios based on agesa 1006?
Ok ryzen seems the obvious choice here just keep in mind BDO isn't well multi threaded so a 7700k would do much better
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319095
Bios has been updated to the current bios update of 1403 on the asus crosshair vi, and no luck as Im using a kit of rip jaws v 32gb kit 3200 mhz and its stuck at 2133
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319099
guessing it is Hynix based? Did you check my ram guide and try the things there? (I think you did tbh)
Ryzen Ram Guide
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319211
I think that 7700k would be over budget and a bit over kill. I was just told from a classmate to go for 250 GB SSD and a 600+ W PSU in case I wanted to run SLI in the future. Any recommendations there?
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319260
Get the Asus Strix B350-F mobo, MSI mobos are junk
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319476
I don't see that you have a cpu cooler in there. Unless you gonna use the stock one, I suggest you get one, Cooler Master - Hyper 212 EVO is only like 25 - 30 dollars, so would be a good fit.
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319625
I'll probably stick with stock cooler for now, I pick up smite upgrade on holidays when they might be on sale.
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10319895
Total: $1158.34
Ryzen Ram Guide
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10320027
Total: $1158.34
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10320161
I linked a change build for you, get that motherboard and PSU and SSD
Ryzen Ram Guide
https://linustechtips.com/topic/823812-first-pc-build-help/#findComment-10320414
