1 minute ago, drkknghtavngr said:
Does ur system also never exceed 60% power usage????? ?
The percentage depends on the card, and is card specific... Especially with nvidia GPU boost 3.0, the cards will overclock themselves to different speeds, making their power usage different for each card (with the same GPU). There's also the overclock factor where it can bring the power usage up, or the undervolt factor where it can bring it down.
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
4 minutes ago, drkknghtavngr said:
My card is a Zotac 960 4gb Amp. Its factory ocd
Not all factory overclocked "Zotac 960 4GB Amp" will use the same, each GPU requires a different voltage to achieve the same clocks. Also, this means your power delivery system is well enough for a massive GPU overclock.
My card (GTX 1080 G1 Gaming) is running between 95-105% of power usage, as it was factory overclocked, manually overclocked, and is watercooled for a higher boost clock
