What is the difference between these?
I have been looking for a nice set of headphones and I decided of the Corsair Vengeance.
So I have been looking at these: Corsair vengeance 1300 Analog Gaming Headset
But then I saw the Corsair vengeance 1400 Analog Gaming Headset and I can't seem to tell the difference between the two and the 1400's cost $30 more.
Does anyone know the difference? Also if anyone has one of the two could you tell me your thought about them?
https://linustechtips.com/topic/82368-what-is-the-difference-between-these/
The 1400 are a refresh of the 1300. As far as I remember the build quality should be better and they use newer audio drivers than the 1300.
Edit: And here is a video that sorta explains it:
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
I found out after some staring at those 2 headphones. The 1300 has pleather. 1400 is using velour pads. And the 1400 structure has a nice finishing coating. Other than that, there's no other difference in physical appearance I can see. Maybe Corsair made some revision internally.
