Hi,
I recently upgradre from my AMD Athlon II to a Ryzen 5 1600X but I am a little disappointed because I have some minor issues.
Sometimes my pc restarts with no reason. I tested the OS, temperatures and all is ok. My mobo don't allow me to put gaming mode or to use the xmp or amp profile. I updated BIOS with no problems but RAM stay in 2100 MHz. In MSI Live Update appears that the BIOS is not update but in BIOS it is ok.
Specs:
CPU: Ryzen 5 1600X
MOBO: MSI B350 Tomahawk Artic
RAM: G.Skill Ripjaws V DDR4 - 3000 MHz 2x8GB
CPU Cooler: Ekwb-kit L240
PSU: NOX Hummer 750W
GPU: Sapphire Fury 4GB Nitro
Thanks.
https://linustechtips.com/topic/823231-help-ryzen-5-issues/
try an older bios version? im having no problem with mine i would just return it if i was you
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/823231-help-ryzen-5-issues/#findComment-10312842
20 minutes ago, ImNotThere said:
if it restarts randomly its probably psu
have you manually entered tge timings for ram?
and lastly is the ram on the compatibity list for your mobo
Restarts are not frequently, I think that its for this hot summer.
And the RAM in G.Skill web only appears the FlareX for Ryzen
1 minute ago, Mooshi said:
CPUs rarely just not work. Sounds more like mobo settings.
I cannot say the same, I have problems with a FX-8350 of a friends computer.
https://linustechtips.com/topic/823231-help-ryzen-5-issues/#findComment-10312917
5 minutes ago, Baeku said:
Most people think bad about NOX Psu but I don't have any problem since December 2012
Even if it were another brand I would say it's the most likely point of failure. Otherwise it could be your CPU temperatures?
I edit my posts a lot.
https://linustechtips.com/topic/823231-help-ryzen-5-issues/#findComment-10312938
I need to say that in first time I commit a newbye error with the watercooling radiator cause I put the fans in front taking out air instead taking in. That was the hell in a computer case xD I change that and now is so cool 60º, 70º in gaming. but now We have a hot summer here in Spain. It could be that, cause I tested the psu and it works fine.
https://linustechtips.com/topic/823231-help-ryzen-5-issues/#findComment-10312965
The heat could cause the PSU to turn off as a safety mechanism. I would try the computer with a different PSU to see if it's the problem.
https://linustechtips.com/topic/823231-help-ryzen-5-issues/#findComment-10312970
