PC Specs:
CPU: Intel i7 4790k
GPU: Asus R9 290X Direct CU II OC
Mobo: Asus Maximus VII Hero
DDR3: Kingston HyperX Fury 16GB Kit (8x2)
PSU: Seasonic 860W Platinum
I don't know what is causing my computer to shutdown. I have it plugged to a wattage meter for my to test the power consumption of my PC. It is telling me It runs at 108W at idle and 415W at 100% full load. I have already stress tested my PC for 30mins.
The problem occurs at RANDOM. I stress that is it completely RANDOM. I only use my computer to play games so it will definitely occur when I am gaming, but I think that's just a coincidence. Since I don't do anything else on my computer but game, I would assume it could happen even if I don't game. But when I leave my PC on overnight and AFK in an MMO I don't usually run into this problem. Sometimes I even leave my PC online for 4 days straight with any problems. It occurs maybe like 1-3 times a month and gets very annoying to me. Send Help.
https://linustechtips.com/topic/822635-my-pc-randomly-shutsdown-please-help/
Try reducing the OC on your GPU, and no, it is not a coincidence that it is during gaming if your GPU is being stressed at a clockspeed that it can't handle. if it shuts off during a game then that often means that you need to reduce your OC.
Make sure your OC is stable. Also make sure there is airflow going to your psu in case its getting too hot from load and safety shutting down. 30min I find is usually not a long enough stress test for daily use. You need at least 12 hours to consider it fully stable
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
I usually only play League of Legends due to working full time, so my GPU never reaches very high, I don't know if that's the issue.
Edited by yhmarvin
Adding more detail
I would assume it's stable because it's factory OC'd right or am I wrong about that?
