Hello so I actually already made a post about what happened to my pc so im sorry for having to make another one but i remebered something. So basically i have this cheap 4 usb port hub that cane be powered externally. I have had this usb hub for months now but i never had an appropriate power plug to have it powered not up until last month when i came across a spare  one. So i immediate plugged the plug in to the socket turned on my pc plugged in my yet unpowered hub and then it happened.
As soon as i plugged in the power cable into the hub the pc shut off and wouldnt turn on again so i thought of the cmos and decided to reset it and then it turned on for a few seconds and turned off again so when that didnt work i tried fully replacing it and the same thing happened when even that didnt work i suspected my brand new power supply so i tried another one to no avail. This got me really worried i replaced the thermal paste on my cpu replaced the ram but still nothing works. I am afraid this might have fried something on my motherboard but i needed to make sure and also i font know if this helps or not but after every major change i do to the motherboard like reseating a cable or something or resseting the cmos it would turn on for 2 seconds and then turns off again. Also after turning off permenantly any connected device would still recieve power through the usb ports.
PC SPECS:
I3-4150
8GB Ram
FSP Hydro G 850 W modular power supply
Rosewill fbm 01
https://linustechtips.com/topic/822353-externally-powered-usb-hub-killed-computer/
its a usb killer in disguise
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
