Hello.
I am looking for a case that supports an E-atx motheboard, 360 front mounted AIO and preferably Tempered glass side panel. I have no budget for the case but don't want to spend like 300-400$.
The motherboard I will be using is the Asus Zenith Extreme which is 277mm/10.9inches in width. I was looking at the Enthoo Pro M and I know, it only supports E-ATX up to 264mm but I have seen some pictures with a 272mm motheboard and it fit but covered rubber grommets which doesn't bother me at all as long as I can get cables through.
If i missed anything important just ask. Thank you in advance for your help.
https://linustechtips.com/topic/821635-need-help-finding-an-e-atx-case/
Just some bapo nerd from 'Straya
PCs:
Main: i7 7700K (5GHz 1.4V) | ASUS GTX 1080 TURBO | 4x8GB Corsair Vengeance 3000MHz (3200MHz CL14 1.365V) | ASUS PRIME Z270-AR | Thermaltake SMART 750P | Coolermaster Seidon 240P | Acer Predator X34 (34" 1440p144Hz GSync IPS)
Secondary: i5 3570K | Intel HD4000 (RIP Sapphire HD 6850) | 2x2GB + 1x4GB Kingston 1600MHz | ASUS P8Z68-V LX | Corsair CX650 | Coolermaster Hyper D92 | Sony Bravia VPL-VW80 (108" 1080p60Hz projector)
Laptop: i7 7700HQ | GTX 1060 6GB MXM | 2x16GB SODIMM | OEM Acer Motherboard | 17.3" Screen (1080p60Hz IPS)
iMac: Core 2 Duo T7400 | ATI Radeon X1600 | 2x1GB 667MHz DDR2 | 20" Screen
6 minutes ago, DekaRanger said:
Hello.
Phtanks has some good options:
http://www.phanteks.com/Enthoo-Elite.html
http://www.phanteks.com/Enthoo-Luxe-TemperedGlass.html
This entire list is full of EATX cases:
https://pcpartpicker.com/products/case/#f=3
the unit I like the most is this:
https://pcpartpicker.com/product/wrvZxr/be-quiet-dark-base-pro-900-orange-atx-full-tower-case-bgw10
but it's really expensive. i would also recommend this:
https://pcpartpicker.com/product/yLvRsY/corsair-case-760tblack
as a cheaper option.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
> Enthoo Elite
Dude, that thing costs $1000...
PCs:
> Enthoo Elite
Oh I actually didn't know that was that much xD
The Luxe would fit the needs though.
NVM
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
1 minute ago, Vandorlot said:
In my opinion it looks hideous but everyone can agree to disagree. Thanks for the recommendation though!
Thermaltake veiw 31 or 21
My Rig
 Peripherals
Look at my more recent one, veiw 31 or 21 for budget. https://www.amazon.com/dp/B06XB53D41?ref=emc_b_5_t
My Rig
 Peripherals
I have the Thermaltake Core G21 on the way but I realized a bit to late that it unfortunately doesn't fit the motherboard. Am I wrong about that or? If it doesn't fit I can send it back since they are very kind about that here.
My Rig
 Peripherals
Send the mobo.
edit- nvm ima take a look
My Rig
 Peripherals
18 minutes ago, awesomegamer919 said:
It says on Phantek's site that it can fit up to 272mm but then I can't use the rubber grommets. I know I said I have no problem covering them but, how will I now pull the cables from?
I wish I could to be honest but unfortunately it is the only one available for the coming weeks since Threadripper is so new. The pc needs to be built asap, that's why I went with it.
No the mobo is good, i need to make myself more clear and double check myself more often. I meant send the name of the mobo, then i realized you already did. Sorry. Now to answer your question the rubber grommets will probably fully covered and it would be a very tough job trying to get the cables through but its possible.
My Rig
 Peripherals
I don't mind it being more difficult as long as it is possible and can be functional. At second thoughts, it is a bit to much glass/acrylic for my use case since I will be in a sort of "gaming house" and I don't want to constantly wash it off since they can't keep their fingers or something like that off it. I know you didn't bring up this case but how about the Enthoo evolv Atx or the Enthoo pro m? As i stated in the beginning, I saw some pictures of the case with a I believe a 272mm motherboard(can't find accurate numbers). https://pcpartpicker.com/b/R2HNnQ
The Zenith Extreme is only a few mm longer, is it possible you believe?
4
Definatly possible as long as your cables bend well. I would not reccomend the pro m because its a dust manget. There arent any filters on the intake
My Rig
 Peripherals
Well there are technically filters and they look like filters but they arent fine enough to stop dust.
My Rig
 Peripherals
Thank you for that information. I didn't know it was a dust magnet. It only has a filter on the front mesh panel and not on the slits unfortunately. I can also sneak some cables through the hard drive slots since I most likely won't need them in the future. I bought the Corsair psu cable kit since I wanted som nice cables but couldn't get cable mod unless I wanted to pay over double the price of it since taxes and stuff like that. Thank you for your help!
