Does wraith cooler suck air inwards or blow air away from the cpu
Solved by Lurick,
They blow it down onto the chip I believe.
You'll want to try and have as much intake into the case as exhaust. So if you have 4 fans then generally, 2 in and 2 out would be ideal (does not account for obstructions or other things blocking airflow)
Edit:
With a trend towards slightly more intake than exhaust being more ideal.
Featured Topics
Shuyaib007 ·
Posted in Audio0 -
6
Sanedish ·
Posted in Troubleshooting0 -
surjava ·
BytePunk ·
Posted in New Builds and Planning1 -
1
6
