Questions regarding bottleneck
Go to solution Solved by PCGuy_5960,
IMO, you should upgrade your CPU before upgrading your GPU. Ryzen 3 and Ryzen 5 are very good options ;)
I have a AMD FX-6100 processor and I am thinking of upgrading to an rx 570 or gtx 1060. Currently I have a R9 270x. I wanted to know how bad will I face bottleneck? I wanted to get a new gpu first and later on to a new processor because my current gpu got broken. Will the bottleneck be too bad or will I be fine playing games like GTA V, CS:GO, Battlefield 1 etc. Also is it going to damage any one of my components if I bottleneck?
It will be highly appreciated if someone answers my aforementioned questions.
Thanks in advance.
https://linustechtips.com/topic/821399-questions-regarding-bottleneck/
The bottleneck will be pretty bad, you won't be running more then medium setting probably. Bottlenecking won't physically damage anything but you might take some emotional damage
Builds:
Thanks in advance.
The bottleneck will be significant. I recommend upgrading to a Ryzen 3 based system if you have the budget.
Bro will I be getting  performance worse than what I am getting with my r9 270x?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
Nope, but I wouldn't expect amazingly much more
Builds:
You will either see very little improvement to almost no improvement. The FX-6100 has a maximum potential of about 50%-70% of say an i7-6700K from what data I can gather.
