Adjust fan speed without PWM?
Solved by W-L,
2 minutes ago, Xdrone said:Ok cool, so if I go through with this purchase of fans and mobo, I will successfully be able to adjust a fan speed curve even if the fans are not PWM using the mobo BIOS?
Yes you'll have the option to vary it within the BIOS.
Featured Topics
DoughmanX_HD ·
Posted in Windows1 -
220VoltsallCore ·
Posted in Operating Systems2 -
Ridoheru ·
Posted in Graphics Cards0 -
EpicAAron ·
Posted in General Discussion0 -
3
Alexis-Ms_Sun21 ·
Posted in Troubleshooting0 -
2
Cramig88 ·
Posted in New Builds and Planning15 -
Ghostsanonymous ·
Posted in Displays3
