Connecting Case Fans
As an update, I've decided to keep the two pre-installed FN V2's as exhausts, and will be connecting them directly to the PSU via a molex to 3x 3pin 7V connector.
This allows both fans to be run in tandem at a set voltage of 7V, straight from the PSU. Hopefully the FN V2's are quiet enough at this level, but if not the same cable comes in a 5V version as well.
I've also bought two BeQuiet Pure Wings 2 140mm DC fans to act as intakes in the front. They will connect to the one remaining available header on my MB, via a splitter cable, and I will then control them in tandem using Speedfan and DC voltage control.
If all goes to plan, this should be give me exactly what I wanted to achieve, and the only concern for me now is whether the included fans are any good or not, and also whether the Pure Wings 2 are any good or not either! I'd have preferred Silent Wings 3, or some other more premium fan, but considering I got both Pure Wings fans for the same price of a single Silent Wings 3 fan, hopefully they'll be good value at least. If not, they can always be returned!
As an aside, the Corsair SP120s are very definitely being returned. I'm well without the return period, but the vendor (Very.co.uk) is willing to accept a return and refund anyway, which is awesome! Honestly the SP120s are just plain awful. They are noisy and whiny and although performance wise they work just fine, they offend my ears a lot!
Thanks to all posters for giving me advice, I know I didn't follow much of it, but the back and forth helped focus my mind on what I wanted to achieve, and hopefully I've finally done so. We shall see! Cheers
