Posted August 11, 2017 hi guys, today i tried overclocking my pc.. i have 4x8 ddr4 corsair led sticks that worked all before overclocking, after that the 4 leds on the ram still work but now windows only recognize 3 sticks what should i do? Link to comment https://linustechtips.com/topic/820509-pc-does-not-recognize-ram/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2017 full spec's please. PC Specs: CPU: Intel Core i7-12700K 3.6 GHz 12-Core CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700 RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40 Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC Case: Corsair 5000D AIRFLOW ATX Mid Tower PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX OS: Windows 11 Pro 64-Bit Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3 Headphones: Corsair VOID PRO Surround Cherry 7.1ch Speakers: Logitech Z213 7W 2.1ch Laptop: Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery NAS Specs: Make & Model: QNAP TS-1277 CPU: AMD Ryzen 5 1600 @Stock Hard Drives: x8 WD Red 2TB SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive) M.2 SSDs: None RAID Configuration: RAID 6 (excluding SSD) Total Storage: 12TB Expansion Cards: None Link to comment https://linustechtips.com/topic/820509-pc-does-not-recognize-ram/#findComment-10283488 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2017 Author 7 minutes ago, Hugs12343 said: full spec's please. Asrock X99 taichi intel 6800k corsair vengeance led 3200mhz 8gb x4 sticks Gigabyte 1080ti Link to comment https://linustechtips.com/topic/820509-pc-does-not-recognize-ram/#findComment-10283512 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2017 you can try reseating the sticks and swapping them for different slots. That could be it. But also try below - lowering the clock speed on the ram sticks to say 2400 mhz and see if that's the problem - if you have other ram, try using that (make sure it's ddr4 - try using just 1 stick of ram (try each dimm) to see which one is the culpret It is very (i mean very very) rare that ram fails especially from a good brand like corsair so it could just be your motherboard. PC Specs: CPU: Intel Core i7-12700K 3.6 GHz 12-Core CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700 RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40 Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC Case: Corsair 5000D AIRFLOW ATX Mid Tower PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX OS: Windows 11 Pro 64-Bit Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3 Headphones: Corsair VOID PRO Surround Cherry 7.1ch Speakers: Logitech Z213 7W 2.1ch Laptop: Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery NAS Specs: Make & Model: QNAP TS-1277 CPU: AMD Ryzen 5 1600 @Stock Hard Drives: x8 WD Red 2TB SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive) M.2 SSDs: None RAID Configuration: RAID 6 (excluding SSD) Total Storage: 12TB Expansion Cards: None Link to comment https://linustechtips.com/topic/820509-pc-does-not-recognize-ram/#findComment-10283542 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
