cpu cooling gone wrong
Solved by MathiasVO053,
11 minutes ago, For Science! said:In the simplest terms, it is to replace all the air in the loop with water. You must switch your pump on, and make sure the air accumulates in the reservoir (it helps to have the reservoir in a high point of the system). I would recommend to unmount your pump and hold it vertical because I think in the horizontal orientation it has a tendency to suck air back in (and if you put the case on its side, the pump is in the low point)
After a good amount of air has accumulated, open the reservoir and fill it with more coolant. then Repeat the process until there is no air in the system.
ok, im not slowly but surely getting better temps, with my gpu sitting at ~47° celcius and cpu sitting at ~65° celcius(both at idle)
