Im considering pushing my GTX 1080 OC as far as possible. My current OC is +120% max power limit, +144hz clock speed and +140hz memory speed.
Ive seen a youtuber push +220hz clock speed and + 500hz memory speed. The catch is the had core voltage at +80%.
My current option for that is locked at +0% but im considering unlocking this and setting it to +80% to stabalise the OC.
My question is, are there any risks/dangers pushing the core voltage to that level. I havent touched core voltage yet but if it helps attain the Max OC I will do.
I have GTX 1080FE but its watercooled with an EK FC1080 and 480mm rad.
https://linustechtips.com/topic/820255-how-achievable-is-this-max-overclock/
As far as I know it may shorten the life but I am not 100% sure
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
You basically can't hurt your GPU with the default bios, just crank it if you want
Builds:
Just now, BRiiTASH said:
Im only keeping it till Volta is announced anyway.
Ok, you might as well try it then
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
5 minutes ago, Gamerguy207 said:
Did the YouTube have any special cooler on there gpu or no. Second you could try his overclock but not as intense ( voltage, clock, etc) and make baby steps to the overclock if you want and test stability
He used an AIO Corsair H95 i think, that was all.
Pascal doesn't really overclock very well anyway, you can increase the clocks but after a point it'll stop giving you any performance benefit, it may even make it worse as I gather they added some kind of error correction algorithm rather than let it crash or produce artifacts. You'll also probably find in reality your card is running way above the advertised clock speed, so overclocking it any further might be hard. That said, you can't really damage modern Nvidia cards by overclocking them, so just try it and see what happens, just keep bumping up the clocks and see what happens.
Once you've figured out what its max stable clock is you might try undervolting it too. Your mileage may vary but on my 1080Ti it'll do exactly the same 2000Mhz at 1.012v as it does whatever the max allowed by the BIOS is, I have no idea how that works or why, I think they just hit a wall and after a certain point more voltage doesn't help. If you Google it, undervolting is a pretty common thing for people to do on Pascal, it'll let it run quieter and at the same speed.
At a certain point, the clock increases will stop giving performance benefits because the GPU is running too warm.  For instance, a GPU that runs very well with the core at 2100 @ 60c, will perform better at 20c.  Likewise, pushing the core clock higher with warmer temps won't yield but marginal results, if any at all, as opposed to doing the same thing with the core temps very low.
It's all about the core temps with Pascal.  The cooler you keep them, the higher they'll be able to boost, and the better they'll run there.
As for the OP.  There's absolutely nothing in the stock bios that's going to allow you to hurt your GPU.  Just remember...the cooler the better.  With the FE model, you'll likely hit the power limit perf cap, long before you find the max overclock of your GPU.
CPU: Ryzen 1600X @ 4.15ghz  MB: ASUS Crosshair VI Mem: 32GB GSkill TridenZ 3200
GPU: 1080 FTW PSU: EVGA SuperNova 1000P2 / EVGA SuperNova 750P2  SSD: 512GB Samsung 950 PRO
HD: 2 x 1TB WD Black in RAID 0  Cooling: Custom cooling loop on CPU and GPU  OS: Windows 10
5ghz is possible if you don't mind using a transformer to power your GPU instead.
MAD-BOX Ryzen 1600X - ASRock X370 Killer SLI - Sapphire R9 Fury NITRO+  -Fried it... RIP
Xeon e5640 4.35ghz, CoolerMaster Seidon 240V, ASUS P6X58D-E, DDR3 8GB 1636mhz CL9, Sapphire Fury Nitro OC+, 2x Stone age storage @ 7200RPM, Crucial 960GB SSD, NZXT S340, Silverstone Strider Gold Evolution, Steelseries RIVAL, Mechanical Metal keyboard, Boogie Bug Aimb mouse pad.
When unlocking my core voltage in msi afterburner it gives me the option to force "constant voltage". I understand this is neccessary for manually OCing a cpu, but is this neccessary for OCing the gpu when applying a core voltage % increase to stabalise the overclock.
2 hours ago, BRiiTASH said:
Ok so i didnt realise i was actually running a +240hz on core clock speed anyway and +140 on memory. Im going to test it at +245hz Core clock and +496 memory with +50% core voltage and see what happens.
By setting an offset on the core, you're allowing the software to create a frequency / voltage curve for you.  You'd be much better off setting the voltage / frequency curve yourself.
Honestly no idea how to do that. I can set a custom fan curve but thats about it. Any tips on how to do it afterburner would be appreciated.
