I was just looking for some opinions on my build. https://pcpartpicker.com/list/mp9hzM I was wondering if the i5 will bottleneck the 1080 or do you guys think its fine? This is my first time preparing to build a computer so i'm not sure if this is the best option. I'm planning on sticking with intel just because amd chip set motherboards don't have all of the features i'm looking for. Please leave any suggestions for me it would really help.
https://linustechtips.com/topic/820109-how-does-my-build-look/
just wondering what does AMD lack features of that you will be using?? I'd like to know what it lacks for a consumer that affects anything. Sincerely wondering not trying to be a smart ass.
the build seems very solid, how ever the there are many better mouses than razer at that price point but if you just like the looks that is up to you
https://linustechtips.com/topic/820109-how-does-my-build-look/#findComment-10278595
5 minutes ago, PCNoobie said:
is this for editing?
Mainly Gaming
11 minutes ago, RoryDash said:
Looks pretty solid :) Hope the build goes well and post a picture when done!
Thanks!
I need a motherboard with good onboard WiFi, if you can find a black or white board with good WiFi please feel free to show me. If you do what AMD card would you recommend to get along with it? As well what mouse would you recommend my friend said he had one and that it works great but if there is something better I can get for the same price or something you personally use.
https://linustechtips.com/topic/820109-how-does-my-build-look/#findComment-10278688
1 minute ago, Awsomestar123456 said:
Would a i7 be overkill?
For a 1080, mainly gaming, and if you mean a 7700K, you should go with that, opposed to Ryzen, because Ryzen is better for editing/creation and a bit less good for gaming than i7
"I'm not really that old, I'm just 18 + shipping" -Unknown
Please tell me why you aren't on dark theme already.
Herro my dark theme brothers.
Laptop: MacBook Pro Mid-2012 Non-Retinai7-3720QM, 8GB DDR3L-1600, 250GB SSD, macOS 10.13
Phone: iPhone 7 Plus that is patiently waiting to be jailbroken.
https://linustechtips.com/topic/820109-how-does-my-build-look/#findComment-10278815
